Looking for alternative RAM-Chips for Travelpilot devices
Re: Looking for alternative RAM-Chips for Travelpilot devices
All of them are for so called "Commercial Temperature Range" which is 0° up to 70° Celcius. So, it COULD be that they work at lower or higher temps, but it's not safe. Need to check for every single chip used. Could also fail after a while.
Best would be to have a "Industrial Temperature Range" which is -40° up to +85° Celcius.
I tried to find Samsung chips like K4H510838*-ICCC or K4H510838*-PCCC, which are in that range. But could not find any...
sanndo
Post by sanndo »
Superrr!! Very useful information! I will search local marked for second hand ddr's and try to get back to life 2 dead FX units I have ;)
cipicas
Starter
Post by cipicas »
Hynix are rated -55 ~ 125.I prefer kingmax as are a little bit more reliable and already tested by me in cold environment ( freezer ) :)
Cheers
Ciprian
cipicas
Starter
Post by cipicas »
corsair
64mb8bdcg testing unit (no datasheet)
normal start, entering freezer.
Ciprian
cipicas wrote: 02 Feb 2021, 10:34 Hynix are rated -55 ~ 125.
That wrong pal. You mixed this up with "Storage temperature". The operating temp is only 0-70 degrees like here from the datasheet:
sanndo
Post by sanndo »
Go4IT wrote: 20 Mar 2021, 08:43 ... The operating temp is only 0-70 degrees...
/// offtopic !!
who cares man :) global warming coming, don't worry about negative degrees :lol: sorry for joke :roll:
cipicas
Starter
Post by cipicas »
Sorry my mistake.
Ciprian
