Point takenDGAlexandru wrote: ↑11 Jan 2021, 07:04 Sevebe, did you analyse the dump he has put in the first message?
Please read my first mesage / look at the explaining image I've put there...
This is not because of a flashing problem. It is a hardware problem: the TTL mux / demux chip that is between MAC and External Flash is not working as it should.
In terms of hardware repair I know you have a lot of tools to play with so yes, you could help him with replacing the components that are damaged.
Tomy75 is from Slovakia.
CONVERS-external FLASH has been corrupted
Re: CONVERS-external FLASH has been corrupted
Digimod
