Page 2 of 4
Re: MCA reverse video
Posted: 27 Apr 2019, 14:21
by Gwe89
Hey I just had a thought does the convers send CAN data to the MCA to switch to AUX port/radio ect...
Posted: 27 Apr 2019, 16:21
by Go4IT
Gwe89 wrote: ↑27 Apr 2019, 14:21 Hey I just had a thought does the convers send CAN data to the MCA to switch to AUX port/radio ect...
Of course. All you can do in Convers is send as a CAN message.
Posted: 27 Apr 2019, 16:59
by bigi
thats interesting - as it would be good to make it so it auto switches the input to AUX when selecting the second video input; then when selecting it camn switch the video input and audio inputs via multiple relays too.
I wasn't sure if the buttons where working via LINbus - but as you can select inputs on the convers it must be using MM-CAN. what i am not sure of is if all MCA messages are sent via ID 433?
Posted: 27 Apr 2019, 18:12
by Gwe89
Go4IT wrote: ↑27 Apr 2019, 16:21
Thanks do you know what ID this would be would they be sent on the 433
Posted: 27 Apr 2019, 19:03
by Gwe89
So
1E6: 00 0C E4 9B 00
Switches the convers to aux for a few brief seconds but MCA stays on radio
This is all bench set up
Convers+ wired to MCA via MM-CAN
and my canbus log tool, I logged mm with ucds which you have to log on ms with this then i played it back and the MCA and convers went to AUX so I'm slowly going through the log to find the right ID and data
Posted: 27 Apr 2019, 20:21
by Gwe89
Found it
To switch to AUX
1F2: 29 0B 00 FF FF A0 00 00
MM-CAN
Found
1F2: 20 07 00 FF FF A0 00 00
switches to radio
Posted: 29 Apr 2019, 08:51
by oscarboiro
Gwe89 wrote: ↑27 Apr 2019, 20:21 Found it
To switch to AUX
MM-CAN
Found
switches to radio
Thanks!!, in my Kuga is not possible control the NX, and my UCDS dont read any command, i don´t know the mondeo/smax have this option from the convers+.
Exist another command to control NX from the convers+? im interested to play with this signals, is possible calculate another command?
Now one question to my proyect, i have solved all software problems, now i have installed the video switch. my first option is a intall a MAX4310 to 2 video input signals or 4311 to 3 video input, but to this pic exist only in SMD format and no good to test in my protoboard. after read some articles from video signal, i try to use 2 transistor NPN, i have some PN2222A, the problem is calculate the correct resistor to the base, i don´t know the consumption of video signal to calculate. i try with base resistor with 5Kohm, but have a little distortion in the image, later try with 4Kohm and 2Kohm and this options work fine, not heat the transistor. my questios is, what i need to calculate the best resistor value? is good option use the transistor, or is better think to install a MAX4310/4311?
i install 2 led to watch when the arduino switch, but i only install to first test, my purpose is take it out the LEDS.
I set preference to put rear video signal when put rear knob, and after turn off the rear signal, return to video mode. when you have a video mode of, after turn of the rear signal, the camera is activate 15 seconds, same of genuine.
Posted: 30 Apr 2019, 21:16
by bigi
So this has been worked on quite a bit in the last week or so!
I have been making a hybrid solution - using the VideoIn Conversmod addition to switch the video, but using custom code to replace the video in adapter. so far, on receipt of the activation code, it switches a relay for the secondary video input, and also switches the stereo to aux input. I am also going to add another relay trigger to switch the AUX input audio lines as well but that is not as important. on receiving the video off message, the video returns to the rear camera, and also turns the MCA input back to DAB Radio. It also has logic to switch the video back to RVC in the event it receives the rerverse signal. so far so good :)
But now i want to improve it even more :lol:
1. I would like to make it so after switching to AUX and custom video, upon switching back it goes back to the last source - but to do that it would need to know what it was - is there a way that can be done?
2. Eventually I want to make it independent of the convermod addon, for example (if possible) by detecting someone pressing the "INFO" button on the MCA to activate the video input - is there a way to do this or will this be an internal code? I suspect it must be sending something out for the convers info? when selecting another input i would need to capture to allow it to switch back - again it depends upon if the sources send anything out.
Here is my code so far - comments welcome :)
Posted: 01 May 2019, 09:15
by Gwe89
oscarboiro wrote: ↑29 Apr 2019, 08:51
To switch to AUX
MM-CAN
Found
switches to radio
Ucds dont log MM-CAN but I found if you make an obd adapter that connects the MM-CAN wires to MS-CAN wires of the ucds you can then log MM-CAN because they use the same 125k speed this is possible you can then play the data back to see if you have captured the data you need I then start deleting lines from the log and play it back and if the input stops then it's in the part that I deleted so it narrows the canbus data down so I have alot less data to go through I then play each one back till I find the one I need
Posted: 01 May 2019, 10:35
by oscarboiro
My problem is in the kuga mk1, the kuga mk1 only have ms-can and hs-can. In the mondeo mk4 is possible control the nx from the convers+, but in the kuga mk1 I only have steering wheel control to volume + -, forward, reward, mode and voice. And no more options.
