Forscan beta with update support
All software topics
amplified
Re: Forscan beta with update support
Post by amplified »
Any idea why on some cars the list of modules to upgrade is short like ddm and pdm missing whatsoever? Very strange.
scorpionul22
Post by scorpionul22 »
scorpionul22
FORScanSetup2.4.0.test20200415
marekrbk
Post by marekrbk »
scorpionul22 wrote: 17 Apr 2020, 16:45 FORScanSetup2.4.0.test20200415
What is new ?
scorpionul22
Last update 2.3.32 official and update firmware module suport
scorpionul22
last update 2.4.3
+ Support hardware ISO15765 in ELS27 v3/v4 (STN2120 chip), firmware v5.6.4 is required. Warning:
please contact ELS27 support team for proper update procedure, as Scantool firmware updater may
not work properly for some ELS27 modifications
+ Configuration and Programming function "Transmission Characterization Update" for models with 10R60 tramsissions:
Explorer 2020 model year
Lincoln Aviator 2020 model year
+ Configuration and Programming function PCM "Reset Speed Limit" for:
Transit 2.2/2.4/3.2 TDCi 2006 model year
+ Service functions "Reset Fuel Injector Adaptation Cylinder 1..4",
"Reset pilot injection quantity learned values - Cylinder 1..4",
"Fuel Injector Pilot Correction Learn" for:
Transit (V363 Europe) 2.2 TDCi 2014 model year
* improvement in STN/OBDLink communication procedure: better handling module responses during long
lasting write to flash
* improvements in CAN communication procedure for ELM327-compatible adapters
* changes milliseconds to microseconds in PTFC* PIDs
* added 1.3L ZJ-VE MZR 75PS engine to Mazda 2 Central Configuration function
* improvements in the procedure that reads part numbers
- bug in built-in outcode/incode calculator that failed gaining PATS security access process on some Mazda vehicles
- bug in "PATS Programming" service function for SA models
- bug loading SBL on some HVAC modules (AM5T-14C239-BB)
- incorrect reading module address in some VBF files
- unability to open VBF files in some cases in Module Programming function Custom mode
- bug in downloading SBL file in the Central Configuration function
- bug in STN chip version detection
scorpionul22
https://cyanlabs.net/applications/syn3-updater/
sync 3 firmware and maps update 08/2020
scorpionul22
v5.6.4 - 2020/10/06
- BUG: Fixed a BUFFER FULL caused by the CAN RX buffer getting filled while waiting for a FC frame during a multi-frame transmission
v5.6.1 - 2020/09/18
- NEW: Added command to change CAN consecutive and flow control frame reception timeouts
- NEW: Added command to specify additional STmin delay
- NEW: Added support for 4 byte header to ATSH
- CHG: Removed CAN deaf time after sending a CAN message
- BUG: Fixed 7Fxx78 message being counted when using STPTO 0
- BUG: Fixed STSLU, STSLVL, and STSLX not working
scorpionul22
marekrbk
Post by marekrbk »
last beta :idea:
