Create own language packs for MK5 IPC
Artist
Re: Create own language packs
Post by Artist »
Yes it is true and absolute necessity. However, I did not create this topic and do not make order, so it is better to follow the logic of the forum itself ...
Re: Create own language packs for MK5 IPC
Don't argue guys, it's so easy to split a topic :D
But i would also suggest to put information about the model into posts to not mix up
leader
Contact:
Post by leader »
Thx Go4IT to split MK5 related information into own thread.
sanndo
Post by sanndo »
leader wrote: 22 Feb 2020, 21:02 ....but I made some tools to help my work...
@leader, can you share your C code tool?
leader
Contact:
Post by leader »
sanndo wrote: 07 Mar 2020, 10:55
The GO code what I posted here was created by analysing the HMI binary in a simple hexeditor and using my brean to identify some logic.
I already discovered the function in IDA and Ghidra to process the language area, and extracted all the references for menu items from the file.
At the moment I'm working on a tool to parse exactly the same way the menu elements like the HDMI program.
It seems that my old GO code has some mistakes, so I think that is not usable...
Of course I will post the code of my current development if i will finish it.
