Page 2 of 2
Re: FX update from 0318_0804018 to higher
Posted: 28 Mar 2021, 21:18
by Artist
I found a DVD in one damaged drive.
I'm sharing a copy of the DVD in Iso format ...
dvd2-EUR+TUR_HSRNS_2009 v2
Title: Ford HSRNS EUR 2009
Project-Number: P_Ford_HSRNS
Project-Name: EUR 2009 FX
Worm: dvd2-EUR+TUR_HSRNS_2009 v2
FX NAV-Server: DI_SWNAVI6.4 C1P19
Boot-Reg.: ford_hs2
Default-Sprache: [_ g_ 01 m] deutsch
Nav-Data: SD2G-Link_N10I9M7T6/nav2-FORD_HSRNS_EUR_2007.10_CCP_LG10 v5
Map-Source: SD2G-Link_N10I9M7T6
Map-Data: map2-FORD_HSRNS_EUR_2007.10_CCP_ML7 v2
:arrow: • Ford HSRNS EUR 2009 •
Posted: 30 Mar 2021, 15:20
by sanndo
Another 0318 on bench... need to find way grr
Artist, check your mailbox to add permission on file to download it please
Posted: 30 Mar 2021, 19:32
by Artist
I'm sorry, I'm home again after a long time working in DE ...
Just ask and access will be given to everyone except addresses like Blabla1 and the like. Use private addresses. Many people also got access to other Mca, Nx, Fx maps from this forum. In another place I am under another nickname ...
Posted: 05 Apr 2021, 07:03
by Go4IT
sanndo wrote: ↑20 Feb 2020, 15:53 I have content of 2008 CD, but I guess if you burn it, it wont read... I'll share link anyway in pm
No, it won't because the CD is copy protected and you can't copy the protection because it is made of a specific failure on the CD which can't be producted by a burner but only in a CD factory.
The only way to get those units up on firmware is flashing it directly via JTAG with a newer version. If will look mixedup in first, because the firmware on the FGS is not updateable by JTAG, so it thays in the old version. Thus will create funny messages an clipped menues, but if you remember the steps to start the SP after inserting the CD, it will work.
Think is was: Enter PIN => Push NAV+MENU at once to enter Servicemenu => Scroll down by turning the right knob counterclockwise (it will stuck on last entry if turned "enough") => Insert Update-CD and Press right knob to enter the selected update-function => wait 10 secs for the device to read CD content and show update dialog => turn right knob clockwise to select "Continue" button and press knob again. Now it should start the update. Wait for it to finish, even if you see funny dialogs and messages inbetween. After the final restart it has updated the FGS and the device is fully operable.
Hope i remebered the sequence right... please correct if not.
