Import maps from MCA to FX
sanndo
Re: Import maps from MCA to FX
Post by sanndo »
Need to find a way to make new maps for East Europe :D Last is form 2012 and only major roads...
hanssi
Starter
Post by hanssi »
Go4IT wrote: 05 Apr 2020, 18:24 I tried to reproduce what you said, copy the 2019 NX maps over to an SD-Card but the FX (patched Firmware, no CID-Check) will not recognize it as valid maps. Because on DVD there is no cryptnav folder in the root, it put the files from DVD into a cryptnav-folder on the SD. Also tried to use an info.txt from an 2018er FX SD, and also yours, but no luck.
Are you shure there is nothing else needed?
One way to find out what the FX accessed on an SD is to disassemble the firmware to that point, or use an SD-Emulator to know what the firmware is accessing on the SD-Card to check wheather it should use the data or not.
I have only replaced MAP, RNW and LID. I didn't do anything else. All work without problems.
sanndo
Post by sanndo »
Bump up topic... I'm still looking for maps FX 2013/2014 including Greece/Turkey?
sanndo
Post by sanndo »
Looking for this maps:
1 - MCA Russia + MREE V2, V3, V4
2 - NX DVD Europe + Turkey 2014
3 - NX DVD Russia + MREE 2009
4 - FX 2010 EE + Greece + Turkey
if anyone have it, please share :)
cipicas
Starter
Post by cipicas »
navigation Europe ford fx 2015 (218722)
i201 2654
it helps,
cheers
Ciprian
