webasto can bus death
marekrbk
Re: webasto can bus dead
Post by marekrbk »
Go4IT wrote: 05 Feb 2020, 17:34 No, currently not, but i'm working on it. It seems that BDM is not nearly as complicated or expensive than it seems to be. I'll be back with more detail soon...
can you take a picture of your processor? MC9S12DG256.
I need a dump eeprom. 0 to 1680 without write check
User avatar
Stevebe
Re: webasto can bus death
Post by Stevebe »
marekrbk wrote: 10 Feb 2020, 08:47
There is a picture in post. One
Digimod
marekrbk
Post by marekrbk »
are different, up is my picture and the dump should be from the same processor
Here are mine
marekrbk
Post by marekrbk »
ist genau meine,bitte dich eeprom auslesen 0-1680 und 0-1410 ohne prüfung und ende datei .*prn
paxtonix
Post by paxtonix »
same modules are also in Volvo. Some times cheaper that Ford's.
Tourist
marekrbk
Post by marekrbk »
I bought the ucds cable to see if you can brighten up the corpse
Now my XPROG is arrived. Will need some time to get familar with it, and find the pins needed for BDM on the PCB and the XPROG, but then i hopefully can rip-off the firmware. What surprises me is that the vendors did not protect their chips against reading from debug-ports. It is a trivial task to do... strange, eh? Even more because no vender ever expect that somebody needs to read firmware but simply overwrite it. If you have it all by hand, it's shurely the best and simplest way to do...
marekrbk
Post by marekrbk »
Thank you very much for your effort.
marekrbk
Post by marekrbk »
tested with ucds, death mod not work,vbl uploader not work . Idea? Block #0 loading failed. Error: [0x00]
