Nx patch
Re: Nx patch
Gwe89 wrote: 16 Jan 2020, 07:22
Go4IT wrote: 16 Jan 2020, 06:21 Why not find the point go get around the copy-protection ourselfs instead of distributing files from the net? :D
But we already have the files
But also no clue what it is all about... it would be much better to KNOW where and how to void the copy protection, than simply just use it. THIS is what this forum is all about. Remember, this is not gpspower.net, gmshosting.com or such ;-)
sanndo
Re: Nx patch
Post by sanndo »
Patch for FX doesn't turn off copy protection in folder f_ls_rvc (FX with video)... So I can't use my FX with not original cards now grrr
DGAlexandru
Re: Nx patch
Post by DGAlexandru »
Compare patched and original file version of FX without video and then compare original FX without video with original FW with video and see if the bytes that get changed for the patched version for FX w/o video are present in the same way in FX with video... and if yes, then you can patch yours by yourself ;)
sanndo
Re: Nx patch
Post by sanndo »
DGAlexandru wrote: 11 Feb 2021, 18:34 Compare patched....
Original and patched hve a lot of diferenses, because dark theme and other more functionality... this was first I try :(
DGAlexandru
Re: Nx patch
I only saw NX MCA patch.. and here it was easy, only some bytes were patched, from some jumps (to other functions) to "NOP" instructions.
cipicas
Starter
Re: Nx patch
Post by cipicas »
sanndo,
try this one, seems to have both version(Ford_FX_SP4.1_patched_BOTH_FLTheme.iso\dnl\bin\system\arion\f_ls_rvc\),
http://s.go.ro/17xay3yb | password: 649048
Ciprian
sanndo
Re: Nx patch
Post by sanndo »
cipicas wrote: 11 Feb 2021, 20:35 try this one...
Thanks, I will check it
cipicas
Starter
Re: Nx patch
Post by cipicas »
any news?
Ciprian
