Page 2 of 3
				Re: Dither and add features separately to Convers+
				Posted: 29 Dec 2019, 21:30
				by ronald0001
				Artist wrote: ↑29 Dec 2019, 21:20
ronald0001 wrote: ↑29 Dec 2019, 21:11
must wait for my es27 to can update my ipc ....
but it was 20€ so it was not soooooo much
and realy i read and read and read...someone say no ligth pack the other one says with ligth pack....and and and....
hex here hex there change this and this and do this
a little bit to much for me at the moment
i only understand like blabla there and blabla this and blabla more
for me is easier to understand while i reproduce that all
but at the moment i dont have an stn1170 device so i can only read what you are all writing...
so that means dump from cluster (old 2008) with ligth pack not needed anymore----
You did an amazing thing, after some time to figure out the rules and meaning of the forum ... Better now than never ...
i know the meaning of the rules....but i dont know what you want to tell me....but its not listen nice.....
and i am here to learn some things and do my own project (carpc) or you read anywhere give me this and this and this in my view posts....i dont think so
				Posted: 29 Dec 2019, 21:41
				by phx-
				Artist wrote: ↑29 Dec 2019, 20:25
phx- wrote: ↑29 Dec 2019, 20:09
can i use .vbf facelift convers what i downloaded here and just edit it in hex editor neo ? i bit worried but i want to try but i miss fl convers with fl car
 well i just try edit everything what i see and thank you for this
Yes, it's the same at Facelift.
However, when using the IPC uploader, the correct checksum is required to be recalculated. The tutorial is also on the forum ...
thank you
 i just learning now, hex editor its like brain wash for me, but i must learn it if i want to be helpful
				Posted: 29 Dec 2019, 21:57
				by Artist
				to  ronald0001
Don't get me wrong, but I don't understand ...
You write that you are waiting for the cable, I don't care and now it doesn't matter. UCDS will not sell you an easy pack for 20 € and so on !!!
You must have a UCDS cable first
Second, you need to buy credit. As far as I know, package 2 about 40 €
Thirdly, I am talking about the missing light source on UCDS. Other company and aliens have Light pack in order ...
So try to read with understanding.
If you purchased a package, e.g. at Convers mod.de, you can compare the result and agree or disagree with the data blocks that need to be written to the main firmware ...
				Posted: 29 Dec 2019, 23:17
				by ronald0001
				no i dont need a ucds ...
i can use with es27 cm327 the updater from here in the forum.....
with this i can also make a dump of the ipc
i didnt buy c+ over ucdsys (not direct from alex)
to flash only vbf files(updates) also no credits needed....
credits only need to correct milage flash some tuning files and for conversmod
i buy basic c+ mod from conversmod.de install this, or better flash the ipc with my elm327 with modhelper from them....and now i buy ligth pack from them also as addon for the basic mod
so no need for ucds...
also not needed to make a dump of the exe main amd eeprom from the cluster
all possible with the ipc updater wich you can download here in the forum....but need stn1170 device (wich i waiting for es27)
if you want ucds with extendend license you must buy it with minimum of 3 lv1 tokens...sorry but this all i know...
for that all is no ucds needed....
but ok if you have a ucds than be happy but to flash a c+ with vbf files its not needed....
and vbf you can create also yourself with binary files...
also not need to buy it only for conversmod....
and sorry that i ask is someone interesstet that i share my dump from basic mod with ligth pack when es27 arrived...that was all...
cuz like i understand nobody had ligthpack to share to put it in the "free" c+ mod files....
				Posted: 29 Dec 2019, 23:28
				by Artist
				Published files come from UCDS ...
Other public sources are not ...
They serve as the basis and understanding of things.
OK, one more explanation "someone say no ligth pack the other one says with ligth pack....and and and...."  These are your words.
Who says that and where is UCDS with a light pack?
Maybe I missed it ...
P.S: I'm not talking about UCDS as my cable, how do you know I have UCDS ???
Everything you write and answer can be read on the forum and everyone knows it ... Save time and avoid duplicating posts ...
				Posted: 29 Dec 2019, 23:49
				by ronald0001
				ok i am out...seems like you dont want to understand....
have a nice time
aha and a conversmod from ucds is other mod than free one or buyed from conversmod.de
or i am to stupid for all
tell me exactly why i NEED a UCDS.....for what???
no better let it...i go working in my canbus blocker and my carpc....
bebey
				Posted: 30 Dec 2019, 01:55
				by DGAlexandru
				UC DS has "Light" correction - as in "show car image with lights only when you have small beam or high beam on" .. and this is explained also in UC DS on the same page
As for ronald0001 he has official Convers Mod "stage1" that is also present in UC DS.
Now he paid Convers Mod another 20EUR to also have Light Pack installed, but in order to be able to do this, he has to wait for his ELS27 adapter.
After he will get his adapter he wants to help us with the dump of his modified Convers, which is from 2008.
				Posted: 30 Dec 2019, 08:19
				by Artist
				The UCDS page states: "Light – Correct show difference between ambient lights and main front light"
After buying from UCDS, I never had any difference in switching on the lights. When recording UCDS firmware I also had no lights !!! I tested it and I see the difference !!!
So I made another mistake? I would like to know what I didn't do with the light mode.
Now after adding blocks directly from software coming directly from Motral I see the difference !!!
Here is evidence that eg. if you leave the old data at 000163 dB
It also releases old headlights and new resolution lights that the UCDS version did not have !!!
				Posted: 30 Dec 2019, 10:26
				by DGAlexandru
				Artist wrote: ↑30 Dec 2019, 08:19
This is what I said also.
OEM FW fill show image of car with headlights from the moment you move the Light Switch to "ambient light".
"Lights" mod (UC DS package) will show you the same image only when you move the Light Switch from "ambient light" to "low beam".
"Lights Package" it will show different images for low beam and high beam, show turning lights, and in newer versions it also shows different image when you have your fog lights on.
				Posted: 30 Dec 2019, 10:34
				by paxtonix
				Artist wrote: ↑29 Dec 2019, 20:19
UCDS offers 3 packages specially for the Facelift version for old cars.
I paid package 2. But they lie and there is no functional Light pack.
The published version of the cracked firmware was even higher than mine, the package number. 3. Which contained other color themes but did not contain Light Pack!
now I understand what's going on. These are simply versions with fewer functions available in UCDS files.
I didn't think they could be useful for anything.
I have only provided full versions.
regarding lightpack - images and strings are mixed up in MAIN and FLASH. That is why it is not so easy to copy hex records from one to another. UCDS don't have it because m0tral gave up on UCDS and start selling on his own. that is why all nice features were not presented in the UCDS software.
the full software have BAT-TEMP-PTC-PA-DS-LIGHT- cTheme-TURBO-DPF- VideoIN -
each of them has a patch for functions like belt, airbag, acc fix, and so on.
In my opinion buying the cheaper versions is just money waste
