How to read/write 24C16 EEPROM of IPc in-circuit
Post Reply
Pro
Post by Go4IT »
Using a RT809h Flash programmer you can read/write in-circuit without desoldering the EEPROM. Of course you do this while the cluster is not powered up!
User avatar
Stevebe
Pro
Re: reading and writing to 24c16A in circuit
Post by Stevebe »
Go4IT wrote: 26 Jun 2019, 20:35 I can tell, that using an RT809h Flash programmer, you can also read/write in-circuit without desoldering the EEPROM.
I use the cheap
works brill read write in situe.
Digimod
Pro
Re: How to read/write 24C16 EEPROM of IPc in-circuit
Post by Go4IT »
The TL866* is not able to read/write the EEPROM in-circuit. It fails if you try. So if you have only this one, you need to desolder the chip to read or program it.
Post Reply
