### Added
- Saving a Converted Image as BIN now asks for type of flash where it will be used and also at which offset will be written to - like when you save the Converted Image as VBF. This is to help adding new images in BIN format easier.
- Images that are found and have their data modified in order to redirect to other image are now shown in the table with a "(R)" from Replaced. CH will show the new image. If you want to see the original image in CH you have to edit the VBF / BIN file and redo the original image frame (Start of Image Frame and Start of Image Data).
### Improvement
- Finding and showing images that are present in VBF / BIN files. Now it finds also images encoded with a LUT table less than 256 colors.
- Again, a lot of code rework. Now it should show that there is a problem in decoding the image instead of crashing.
I got used to the Wide format version.. so in the near future I might drop off the old "more square" format version.
For now they are both included.
