Swap ABS module
Post Reply
Pro
Swap ABS module
Post by Go4IT »
Hi, i'd like to swap my ABS pump to gain HLA (hill-launch-assist) and prepare ACC functionality. I have bought at CG91-2C405-FB pump to replace my BG91-2C405-AB.
I know that PATS data is stored inside the ABS module, and after swap i need to do some reprogramming but have no idea how to do it. IDS should be able, but i don't have it, and think i also need a special/supported adapter like VCM, VCXDIAG.
I have a UCDS, but i do not see any support in the software for this programming...
Any help from you guys? :)
avladimir
Starter
Re: Swap ABS module
Post by avladimir »
For facelift you need to have an IDS or FDRS with a dealer account. You can use FDRS with your UCDS cable, but you still need a valid subscription.
DGAlexandru
Pro
Re: Swap ABS module
Post by DGAlexandru »
You can also use ForScan, but you need OutCode -> InCode calculator .. which is available on Zed-Full for example .. so the needed code can also be retreived by phone / WatsApp...
marekrbk
Active member
Re: Swap ABS module
Post by marekrbk »
Go4IT wrote: 08 Nov 2020, 02:06 Hi, i'd like to swap my ABS pump to gain HLA (hill-launch-assist) and prepare ACC functionality. I have bought at CG91-2C405-FB pump to replace my BG91-2C405-AB.
Du kannst die ABS zuerst anschließen, ohne sie zerlegen zu müssen. dann uber forscan programieren,wenn hast du erfolg ,dann machst du abs tauschen im auto . Du must nicht gleich tauschen . habe auch gemacht so ,weil wolte nich zum ford handler gehen . alles hat funkcioniert und dann habe gewechsel abs pumpe .
User avatar
uscovu
Starter
Re: Swap ABS module
Post by uscovu »
Hi,
If you swap the module, the new module must be initialized and this function will erase all learned keys and you have to reprogrammed minimum 2 keys. Like DGAlexandru wrote, you need this incode<->outcode calculator, if your car is a prefl it is very easy to do it because there a few tools (I can give you one) who can calculate these codes.
Gwe89
Pro
Re: Swap ABS module
Post by Gwe89 »
Theres no incode > outcode calculator for facelift unfortunately so would need someone with a ford dealers account
Post Reply
