Switch between Miles and Kilometers
Post Reply
Pro
Re: reading and writing to 24c16A in circuit
Post by Go4IT »
Nice Steveb! :)
Here is the link you mention: https://mk4-wiki.denkdose.de/artikel/ip ... umbau_typ3
It's not easy to find the flag, because each and every EEPROM is a bit different, because of software versions on the clock, etc. But it would be a good bet to look in the are where the kmh/mph resides. It may also be just a byte acting as a flag. When you suspect one, change it and retry until you find it. It shure be a hell of a job, but i did such things myself and sometimes fortune will help.
User avatar
Stevebe
Pro
Post by Stevebe »
After spend a bit of time compairing several 24c16 files be it Diesel or Petrol the difference on 1112 1122 1412 all showed the same
address 0x97 Km=0x01 and MPH 0x00 this was the case on both convers the petrol middle convers and the Diesel FL 1412.
ignor the lower part its just 097
Digimod
Pro
Post by Go4IT »
? Address 0x97 of the EEPROM contains unit, be 0x00 for MPH and 0x01 for KMH.
User avatar
Stevebe
Pro
Post by Stevebe »
Go4IT wrote: ↑08 Apr 2019, 15:12 ? Address 0x97 of the EEPROM contains unit, be 0x00 for MPH and 0x01 for KMH.
Yes that is what I meant to say, thanks Go4it.
Digimod
User avatar
Ursadon
Active member
Post by Ursadon »
Yes, at 0x97 - KM/MLS switch :)
I'm Looking for odometer value. As i know, it saved as divided by 16
Post Reply
