Apply custom animation to Ford Convers+
hanssi
Starter
Re: Apply custom animation to Ford Convers+
Post by hanssi »
Go4IT wrote: ↑27 Dec 2019, 14:07 Why making a secret out of it and not tell how you did it excatly? Like already said you replaced the animated pictures with others, which is not so hard to do... but after all, a nice idea and you did it well :)
But, keep in mind that this is not a "teaser" forum, or a selling plattform. If you have something to share (in the means of knowledge) do it, but do it so others can learn from it, like you did from us here.
There's no secret here. It's the same procedure with the custom logo, but it must be used on 11 images in the flash file.
Step 1) take ConversHacker and show "welcome pictures 400x198 pixels" and addresses
Step 2) place new pictures to free space into flash file
Step 3) redirect old addresses to new pictures
And you're right, we forgot one thing :
Step 4)delete text "menu control" in Main file.
Done.
Artist
Active member
Post by Artist »
Deleting text is not a good choice. The active part does not disappear ... And it is not a good idea to cancel the "Help" screen to display the Alarm Acknowledgment option.
In addition, anyone can choose to start an animated conversation or instantly view the Control menu without any effects!
p.s: Ok " Menu Control "
hanssi
Starter
Post by hanssi »
Artist wrote: ↑27 Dec 2019, 16:59 Deleting text is not a good choice. The active part does not disappear ... And it is not a good idea to cancel the "Help" screen to display the Alarm Acknowledgment option.
Hi Artist,
we're on the same? I mean this text.
This text has no function and can be replaced for example by spaces.
Please correct me if this is not true.
Artist
Active member
Post by Artist »
yes, "p.s" in my post ...
I have to explain it, I swapped it with the Help screen!
So yes this text aesthetically annoys in animation ...
tomy75
Active member
Post by tomy75 »
im upload source files for the animation
viewtopic.php?f=25&t=98#p914
Post Reply
