disassembling travelpilot fx firmware system.elf file
DGAlexandru
Pro
Re: disassembling travelpilot fx firmware system.elf file
Post by DGAlexandru »
oscarboiro wrote: 07 Feb 2020, 10:38 Only connect de Data+ and Data- but the problem comes wit the driver.
next step is found a driver, but i think so hard to fount it.
Do not forget about GND.. without this one you could blow UP things :)
Put also an image with Hardware IDs from Details section of that found device.
oscarboiro
Active member
Post by oscarboiro »
some screenshots:
hadware id:
Kuga MK1 owner
tomy75
Active member
Post by tomy75 »
Can you set windows to english?
You working with win7 or win10?
oscarboiro
Active member
tomy75 wrote: 07 Feb 2020, 17:21 Can you set windows to english?
Yes, when I arrive to home change settings and take new screen shots.
Kuga MK1 owner
tomy75
Active member
Post by tomy75 »
Thenx
Can you conect to apple computer?
Pro
Post by Go4IT »
I already was there a while ago... but even with driver the question remains what to do with it... https://mk4-wiki.denkdose.de/artikel/na ... chse_x3806
This USB is connected to the OMAP, i think one could be able to boot it from USB, maybe also put firmware on flash.
DGAlexandru
Pro
As long as you see it as a device when it's connected to a PC, then this is a slave port... so it can act as a storage device, a serial port adapter or some other debug port.
tomy75
Active member
Post by tomy75 »
oscarboiro
you conect Fx when its power On or power Off?
oscarboiro
Active member
tomy75 wrote: 08 Feb 2020, 14:30 oscarboiro
With unit power on.
When I have a little time, change the lenguaje in my windows and take a new screen shots.
Kuga MK1 owner
Pro
Post by Go4IT »
This port seems to be only active for a short while. If you read the TI OMAP docs you find that this is usually used for firmware update. Even if you can use an universal USB driver like "zadig" of course you need the "right" software to program it...
Post Reply
