Travelpilot MCA Camera Input
Post Reply
oscarboiro
Active member
Post by oscarboiro »
Im looking a work from Go4IT in a graphics board of travelpilot MCA to install all electronic components of camera imput.
im thinking to buy a travelpilot MCA withouth video input and try to install all components of graphic board to activate video mode, is it possible? exist any list of components needed?
after repair some NX and FX units following this forum instructions i want to try new experience and learning more.
Kuga MK1 owner
DGAlexandru
Pro
Re: Travelpilot MCA Camera Input
Post by DGAlexandru »
Yes, it can be done.
After the hardware mod, you will also need to put the coresponding FW - MCA with RVC.
oscarboiro
Active member
DGAlexandru wrote: 03 Feb 2020, 10:05 Yes, it can be done.
Do you have any list of components?
Kuga MK1 owner
DGAlexandru
Pro
I edited in the past some pictures and added the values for the needed parts, but I cannot find them now.
Go4IT did this work in the past, take a look here: https://mondeo-mk4.de/forum/thread/2098 ... folgreich/
oscarboiro
Active member
DGAlexandru wrote: 03 Feb 2020, 10:32 I edited in the past some pictures and added the values for the needed parts, but I cannot find them now.
thanks, im look the pictures of Go4It but dont have values and component names :cry:
Kuga MK1 owner
Pro
Post by Go4IT »
I have all the necessary information to retrofit. Already did it twice, and it worked right away even without changing the firmware. It's all there inside.
But it's a hell of a job, and i have many handwritten/notes which to sort out before bringing it online.
Post Reply
