Ok the title data from BT shows on SATNAV. It not on convers tried YouTube and music videos all the same. Pictures will show right way up when you open them lolronald0001 wrote: ↑27 Jan 2020, 00:32 ah ok...some pepble told me if the play a song lile from youtube they see information about title in c+....
doesnt matter i can use also the radio stationnames id
Transmitting infodata on MM-CAN
Re: Transmitting infodata on MM-CAN
Digimod
ronald0001
- Active member
steveb...big big thanks....so i let it over the radio station names...
Yes I think that’s the best way just send from the Pironald0001 wrote: ↑27 Jan 2020, 16:11 steveb...big big thanks....so i let it over the radio station names...
Digimod
ronald0001
- Active member
if someone have an idea what i can do also with the pi and can-bus please tell me
i am npt a programmer but i am good in search on google and create my own solutions hahahah
not only copy and paste this is ugly....
at the moment i use almost nodejs and a mqtt server to listen on can and do some actions
but in future i want to do an node app...show all infos from car...
also maybe ro do some actions from there....set temp of climatic...
or replace the fx completely...this was my finish goal to do...maybe someone want help me a little bit...i must look for an dab+ module for the pi...a soundhat...and also an gps tho have also offline navigation...pr an solution how i can charge my phone and connect same time to pi
DGAlexandru
- Pro
Or you could put a Ford Focus 3 or Mondeo MK5 Audio Unit in, with DAB and whatever you want and just controll it with PI on CAN.
The same can be done with FX and NX, but you still need to have their original screen on... at least untill we decode the communication between MainBoard of FX/NX and ScreenBoard.
ronald0001
- Active member
sync 3 in mondeo....overkill haha
no its enough to replace fx eith the raspberry
DGAlexandru
- Pro
Not a Sync 2/3.
Only the Radio-CD-DAB module... it looks like an old CD-ROM drive of a computer.
Something like this:
https://www.ebay.co.uk/itm/Ford-C-Max-1 ... 4036769711
Look for 18C815 and DAB.. if you want with DAB.
Let RPI do only the display part. Do not try to reinvent the wheel with it for DAB / Radio, or any other sound processing / amplification.
ronald0001
- Active member
nono for dab+ i will use welle.io
i must order an rtl2832u or something simular...
thats easier...
more interesst is the can bus for me...wich infos i can show...what i can control and so on
building a carinfopanel and other things
thats easier...
That is indeed a nice idea! Those units are splittet by default and there are good chances to get the communication between both. Do you know if this unit has DAB+ and not only DAB? Because later one is no longer available in Germany.DGAlexandru wrote: ↑28 Jan 2020, 16:47 Look for 18C815 and DAB.. if you want with DAB.
ronald0001
- Active member
https://youtu.be/tL-YkNvjr4w
video filename to c+
