Blaupunkt NX messed after Screen board
Post Reply
amplified
Active member
Post by amplified »
Hi all, i replaced the T-con board behind screen of a faulty NX with part from another - boards same and etc.
But here is what happens: some menus are messed as if address is pointing different stuff. Tried firmware update but yea... one of those NX that doesnt take the update...
DGAlexandru
Pro
Re: Blaupunkt NX messed after Screen board
Post by DGAlexandru »
Try to connect to the donating NX and read the Flash then write it in the new one; preserve 509 sector; do this by JTAG
amplified
Active member
Post by amplified »
Fixed. Cleaned cd drive and update to 5.3 all menus are fine mow
Post Reply
