Foglights as DRL (auto on)
Post Reply
sanndo
Starter
Post by sanndo » 10 Mar 2020, 17:07
Did anyone find a way how to autostart foglights to work as DRLs?
Without relay or hardware.
tasicky
Starter
Re: Foglights as DRL (auto on)
Post by tasicky » 11 Mar 2020, 18:42
Its not possible without modification in BCM firmware.
amplified
Starter
Post by amplified » 11 Mar 2020, 21:32
anybody sniffed on CAN signal when button for fogs is on?
tasicky
Starter
Post by tasicky » 12 Mar 2020, 18:49
Light switch module is connected to bcm via LIN bus. Fog light are connected directly to BCM. All logic and relay functions are closed in bcm. I think than on mscan you can find only status of this light.
User avatar
Stevebe
Active member
Post by Stevebe » 27 Mar 2020, 19:29
amplified wrote:
11 Mar 2020, 21:32
i have a capture of the LIN bus from the switch if its of any help
Digimod
Pro
Post by Go4IT » 22 May 2020, 06:43
tasicky wrote:
12 Mar 2020, 18:49
Correct, like for many other signals also. As the foglights are also directly connected to the BCM, all logic is inside this module. The only chance i see to control it via CAN from outside the BCM is to use service control routines of diagnostic services. I don't know how but i am absolutely shure that there exists service calls to get every input signal status and set every output status. BUT - establishing a diagnostic session while driving is maybe a BAD idea :D
User avatar
uscovu
Post by uscovu » 02 Jul 2020, 09:42
Hi,
I think you can do it with a relay... It is more simple.
Post Reply
