Create own language packs
Syntax
Re: Create own language packs
Post by Syntax » 28 Jun 2020, 22:34
So I have tried uploading translated VBF to convers and it works correctly at least for the menu strings.
I have found char codes for č and ě but ř is still missing...
And there is a new version online which supports I think most of the strings in the convers (currently ~500 strings from modded version).
http://movinground.org/content/convers-lang/
Post Reply
